1 - 2 of 2 Posts
Downshift baby!!!
Hello everyone, i have read these forums over the years and have always appreciated the great input. I have a 07 accord 4 cyl. The check engine light came on and the dealer diagnosed it as cat converter. I replaced it with aftermarket since i had high mileage and couldn't justify the cost. Then the light would come on occasionally then eventually stayed. It then read camshaft position sensor. I changed both A and B and also the cvt sensor i believe the mechanic said. Now he diagnosed it to be vvt solenoid. Changed that but light still on. Did i mention i also changed plugs recently but used Bosch platinum iridium instead. Light is still on. I'm haunted by the light.
03-SSM-AV6-6MT
The car needs OEM plugs. Also, I'm pretty sure the cat isn't up to Honda's standards. You can try the spark plug defouler trick and see if that helps.
1 - 2 of 2 Posts
