99 Accord EX V6, 90K miles
I recently had a new tranny put in (@ 87K) and replaced the alt and battery at the same time. Recently, while driving the car seemed to lose all electrical power. The entire cluster would go to 0 and this would last 2 or 3 seconds. Only the vehicles momentum seemed to keep it going. Then all of a sudden it comes back to life, as if you just turned it on. You get the seat belt light, the chime, and all. I did notice though that the radio continues to play, so it seems it can't be the alt or battery causing the problem. Checked relays, fuses, etc and they seem ok.
Fast forward a couple of days and now I sometimes have a hard time starting it. It does not seem like the battery as it cranks pretty hard, lights work, etc. Eventually it starts and continues to run and I drive off. I scanned the car and I am getting 3 codes.
P1607 - Engine ECU internal failure
P1491 - EGR lift something
P0420 - Exhaust something.
I am mostly certain the latter 2 are related, but I could not find much searching on the P1607 code. I found folks that say their car throws the code and goes into limp mode, but I have not seen that happen.
Any ideas?
Thanks
ayman
Any ideas?
Thanks
ayman
