21 - 36 of 36 Posts
Amateur home mechanic 馃槀
2009 Accord EX-L
Discussion Starter #21
Motor mounts. Check these, if you didn't disable VCM then they are for sure toast, its a problem with these cars.
Motor mounts looked good when I check them yesterday. Wouldn't they be consistently bad and have a clunking sound as I go over bumps?
Sometimes the balance machine is out of specs. I have had this happen. Tire shop makes all kinds of excuses such as, your rim is bent. You bought tires that are not premium. You are imagining things.
Then you go to a tire shop with a real balance machine in good working order and all problems are solved.
Also could be bad wheel bearings.
2009 Accord EX-L
Discussion Starter #23
Just replaced wheel bearings and I went to a pretty reputable Jack Williams shop. Local HUNTER RoadForce balancers are asking $150+ just for two tires.
2009 Accord EX-L
Discussion Starter #24
Looking into VCM Muzzle, what I'm feeling could be related to the VCM shudder (and spark plug fouling/heavy oil consumption)
IMO and IME, its a bad drive shaft. For the better part of a year on my previous accord (2004 Accord), the car shook between certain speeds only (110-125km/hr). Brought it in to a trusted mechanic and nothing concrete and learned to live/ignore as the car was getting older. One day, wifey hit an epic pothole and massive vibrations ensued. At this point, it was quite clear it was a driveshaft since apparently visually bent. Replaced one driveshaft and ALL vibrations (new, old, speed sensitive COMPLETELY gone).
I profusely thanked the wife for hitting a big pothole! /s
2009 Accord EX-L
Discussion Starter #26
Seems like a couple people are supporting the axle theory, looks like I need to do a 180 and double check it's straight.
I am assuming you have a front wheel drive vehicle? This would mean there is no drive shaft and instead 2 front axles with CV joints. The bearings in the joints can get so worn out that they do cause a noticeable imbalance.
Do you have a Discount Tire? They should be able to balance your tires for about 9 bucks each, free if you buy your tires there.
2009 Accord EX-L
Discussion Starter #28
I've had all tires balanced, got new front tires, balanced and aligned those, and it still happens. Looking into the VCM caused the shake because it feels like a mix of a misfire and a suspension/tire problem. No codes thrown either
VCM DELETE
Did you check the rear motor mount? The VCM will ruin it, many members on here said they disabled the VCM b/c they were sick of paying for 500$ Stealership visits for broken motor mounts. Inspect it VERY CAREFULLY. Mine didn't look bad, but a very good mechanic showed me otherwise. FYI, I have same car as you, 3 years newer.
2009 Accord EX-L
Discussion Starter #30
Did the mechanic show where it was worn at? And could you see it without removing the mount?
You can diagnose which motor mount is bad by holding the brake while tapping the gas pedal with gear in D and R
2009 Accord EX-L
Discussion Starter #32
That's the video I watched the other day haha. I'll have the steal my wife away to try it out today.
Any updates? Btw, did you have your new tires re-balanced at the same place on the same machine? I ask because I went back to the same balance shop 3 times over a period of a few weeks. We even changed the rims with a spare set I had. IT turned out their machine was out of spec. So a bad machine will trick you multiple times.
2009 Accord EX-L
Discussion Starter #34
Yeah it's been the same place, no changes yet, suspension and engine mounts are good, last thing I can think is replacing the last two tires
It has been my experince that front tires out of balance shake your hands on the steering wheel rear tires out of balance shake you bum bum and the people in the back seat.
2009 Accord EX-L
Discussion Starter #36
I feel on and off shaking everywhere, new front Tires. It seems to have shifted towards 70-78mph and still on and off at random. Engine RPM is consistent so not minor misfiring.
21 - 36 of 36 Posts
