Hi folks. Ive decided to create this threadfor my Accord. I always try and take the road less travelled & always do my own work unless I dont have the time or resources to do it.
I always tried to take pics whenever I was adding or taking something off but couldnt always. I want this thread to be here to help my fellow 7th Gen guy that might have a question. Feel free to ask me anything about what I have done so far. I feel blessed to have been given the chance to bring my Accord to the level its & relish in knowing some of the knowledge Ive gained can help the next guy. I got into tuning about a year ago now & will be updating the thread as I go to finish the Accord.I will be tuning it myself on KPRO. Happy Modding!
My Turbo K24a4 Accord Thread
2003 Accord EXL
I bought it January 07 as a "daily driver I would leave bone stock" Well we all know that never lasts! I soon bought an AEM CAI for it & it was downhill from there. I ended up putting a few other mods on it & dynoed roughly 151whp/157ftlbs on a DynoJet dyno.
Here are some pictures of it through the years , as well asthe mods it had when it was NA & the mods currently.
NA Mods:
DIY Intake
Coolant TB Bypass
Neuspeed Shortshift Kit
Corsport Shifter Bushings
TSX IM
TSX 6 Speed Transmission
Hondata IMG
Exedy Stg 1 Clutch
Ebay 7.5lb Flywheel
Ebay Rear Camber Kit
Ebay Header
Ebay Coilovers
Ebay Test Pipe
Ebay Exhaust Piping
350z pre-muffler
Magnaflow Muffler
Ingalls Front Camber Kit
NGK Wideband AF Monitor
JDM S2K 6spd Knob
8000k HIDs
18" G35 Wheels/ 225 40 18 Tires
Current Mods:
Coolant TB Bypass
TSX IM
Exedy Stg 1 Pressure Plate (higher clamping force than ACT HD Plate)
ACT 6 Puck Sprung Clutch Disk
Ebay 7.5lb Flywheel
Jpower Rear Camber Kit
Ebay Coilovers
Ebay Test Pipe
RSR Catback Exhaust
JDM S2K 6spd Knob
8000k HIDs
Greddy Turbo Kit 6psi
Goodridge Oil Lines
HKS BOV
Garrett Boost Gauge
KPRO - PNF ECU
CHAM KPRO Harness (modified by me)
RSX-S AF Sensor
First Mod! - Replaced stock 16" wheels w 05 Civic Si 16" Wheels
Blacked Out The OEM Headlights & added an AEM CAI
Install wasnt too bad but I did have to remove the bumper.
Consisted of clips mainly, 10mm bolts & phillips screws.
Tools Need:
Phillips Screwdriver
Flat head Scredriver
10mm Ratchet with extensions
Use flathead to install couplers and to remove the plastic pins securing the bumper
April 2007 - 18x7 TSW Wheels - 205 40 18 Tires - Lowered on Neuspeed Sport Springs
Install required :
Jack
Jack Stands
spring compressors
17mm impact socket
17mm Wrench
12mm Wrench (I believe, for top but on shock)
14mm impact socket
Allen head for top of shocks
Install was about 3-4 hours because I was drinking beer
September 2007 - Converting from 5Spd 4.4FD to TSX 6spd 4.7FD
Had a local shop owner take the tranny apart to make sure it was in tip top shape. It was!! Many thanks to the guy who shipped me the 2005 TSX transmission from NY to TX & gave me a great deal!
Install :
Advanced-
If youre not well versed in mechanics & have done transmissions before, then dont try this lol. I took the plunge simply because all the local shops wanted $1200-$1750 to INSTALL ONLY.
After doing the work, I see why they would charge that.
Just look at the pictures to see the work involved
Had a local shop owner take the tranny apart to make sure it was in tip top shape. It was!! Many thanks to the guy who shipped me the 2005 TSX transmission from NY to TX and gave me a great deal!
NOTE: After taking about a week to adjust to the lightened flywheel, I don't even notice it anymore. I drive in traffic too & its fine. Im just used to it. I love the acceleration too.
Also replaced the broken pickup it came with
Hondata IMG Install
Install:
Moderate. You have to get in some weird angles to access some of the bolts
Extensions, 10mm socket, 12mm socket, 12mm wrench.
NOTE: I left the lower intake manifold bracket off and left it off. Its been 3 years now & have no issues
Comparisons between the TSX & Accord injector base.
I did this to settle some curiosities as to whether there was a difference in them in regards to power. I was able to measure about a 2mm difference in the TSX injector base. No difference in the runner diameter between the 2
Off Road Suspension Upgrade
Minor wire tuck work
done
ASA AR1 Wheels. 18" 205 40 18 Tires
Later I went with AP1 S2000 wheels since I managed to curb check all the previous ones and crack 1
here comes the BOOOOOST
I am running an RSX Greddy Kit Modified to fit the Accord of course. Running upgraded feed & return line
Due to this I had to drop the subframe quite a bit to be able to pull the pan as to let me tap it for the return line
Total Install Time: 20 Hours
After tuning on emanage at 6.5psi, I went from emanage to FIC.
Heres a clip when I was on emanage.
http://www.youtube.com/watch?v=KYgCp1eJlc4
12/26/09 Motor Blows up
Returns with ARP head studs, cometic head gasket & ACT 6 Puck Clutch disk
Thanks to my boy's shop VIKTEK that handled the work when I was too busy AT work
Fresh k24a4 w/ appx 40k on the clock
Installed an RSR Catback Exhaust and Blitz Dual Turbo timer
