1 - 3 of 3 Posts
On my 2004 v6 I've been havin a problem with the climate contol the passenger side always works good but the drivers side will some time blow cold air when I want hot. When I mess around with it alittle it eventually works. I think it may be the blend door does anyone have any suggestions
You're going to need to have the codes read from the HVAC panel, if you have access to a factory manual you can do this by pushing buttons on the panel in a particular order.
It's possible that one of the blend doors isn't working correctly, either door or motor.
Ok thanks I'll give that a shot a have the manual so I'll check it out
1 - 3 of 3 Posts
