1 - 9 of 9 Posts
Hi,
My parents own a Accord 15 V6 Touring. I rarely drive it since it is not my car but I notice that the car makes this clunking noise going from D to R and R to D.
I was wondering if that is normal?
Elvira
Hi,
depends on how loud or jarring the clunk is. It sounds like it is very common on the 6 speed auto as I have one from 2013. My experience is that it is very quiet almost totally unnoticeable, unless I don't allow a few seconds after stopping the motion of the car to change from R to D.
If it happens everytime and very loudly no matter how long you pause between shifting it could be a problem.
It is especially noticeable during the cold days if the car is not yet warmed up.
My experience anyway we'll see if anyone else can comment.
Dsclmr:DIY @ YourOwnRisks
It does make the clunking noise on mine too; even shifting it back to P. it is an irritating, unhealthy clunking noise; I guess it is normal to them. I had to learn how it behaves and try to avoid the shifting. I guess you have to give it time for every shift even when fully stopped. My experiment is that from P to R, don't put it back to P or it will clunk. And, from P to R to D then to R again, it will clunk. In fact, I can feel when it will make the clunking noise; I guess depending on the shifting pattern, I know it will clunk.
Apparently, the only time I ever get a nasty sound from the transmission is if I reverse, then put it in D, then put it back in R within several seconds. I backed into my driveway recently and realized that the car wasn't centered enough, so I put it in Drive, pulled forward a few feet, straightened up, and then reversed again. It was when I switched back to Reverse that I got a nasty metallic click/clunk that made me cringe. The engine and transmission were warm, too, having been driven about 25 miles just prior. That was something that I did not expect and hadn't heard for quite some time. My 6G V6 used to bang loudly when shifted from P to R and would clunk a bit from R to D, so hearing a similar noise from my 9G V6 was at once disturbing and nostalgic.
Ok, so I went to the parking lot to do some test.
I realized the car makes a "clunk" noise when I switch to reverse when car is still in motion. Like going at 1 mile / hr.
So for example, when I try to back into a parking slot quickly, I switch to R without completely stopping.
@acutee
My car does the same too. Once I reversed the car in and push it back to P, it makes this "clunk".
Runnin' in the 90s
You shouldn't be doing that in the first place...
Does going into drive while still reversing damage an automatic transmission? | Automotive Thinker - Discussing the finer points of automobiles
"Going from reverse to drive while moving slowly will not DAMAGE an automatic transmission, but it is a bad habit. The foreward clutches in your transmission are NOT a substitute for the foot brake, and wear and possible failure will result from chronic reverse/drive or drive/reverse shifts while car is in motion."
BDFR3NT
Ya unless its a manual, should be a complete stop then switch. I am guilty of not completely stopping but its usually R to D but never back again, if I go back I completely stop.
1 - 9 of 9 Posts
