1 - 1 of 1 Posts
Former H Master Tech
Im in the process of ordering some coilovers (most likely Ksports) and am going to order a SPC camber correction kit for the rear. I will be lowering it to the point of zero wheel gap/slight tuck, but not completely slammed. I was wondering if I will need the 3 arm camber correction kit that allows for 3* of camber correction or if i can get away with just the top rod that will only give me 1* of adjustment. And is the front camber adjustment on the pillow mount enough to correct front camber to factory specs?
So, if you guys have any alignment specs/printouts of coilovers w/o camber kits please post them.
Thanks in advance!
1 - 1 of 1 Posts
