Recently I have received questions from several forum members about the conversion from OEM low beam H11 halogen bulbs to brighter H9 halogen bulbs. This OEM H11 is 1,350 lumens; the replacement H9 bulb is 2,100 lumens (see below).
The H9 bulb is available from Amazon for $7.26 each, with free shipping if you have Prime. If not, you will need an order of $25 for free shipping (buy 4 and have spares or share).
Converting to H9 bulbs instead of HID has the disadvantage of having a yellower light than HID. Although H9 light is whiter than H11, it is not as white as HID. The advantages include a better light throw since the Accord projectors are for halogen, not HID. The H9 fitment is the same as the H11; not true of HIDs. The other advantage is the lower initial cost of less than $15.
I am including some back up material below from Daniel Stern Lighting and some pictures from the NASIOC Subaru forum showing the simple mod needed to convert the H9s. The night pictures are of Subaru low beams so they are not directly applicable to our Accord, but give a general idea of H11 low beams (first) and then H9 low beams.
My question and an email response from Daniel Stern concerning '13 Accord low beams:
My question: What do you recommend for a better low beam bulb in a 2013 Accord, which are now H11 55w Stanleys?
Stern's email answer: Your low beams take a 1350-lumen H11 bulb. You can easily, safely, and effectively replace this with a 2100-lumen H9 bulb, which you ought to be able to find locally by seeking the high beam bulb for a 2008 Chevrolet Malibu.
Use a good brand (GE, Philips, Osram-Sylvania) and stick to colorless clear bulbs, not any kind of "whiter light" bulb such as the Sylvania Silver Star scam.
Can also get online, http://store.candlepower.com/h-9.html .You may need to shave a small ridge of plastic off the H9 bulb's connector so that the H11 socket will snap on. Other than that, it's a direct swap.
The only disadvantage is shorter low beam bulb life — the H11 is optimised for very long life with relatively modest light output, while the H9 is optimised for very high output with relatively short life.
Note that the H9 swap is not universal; it works well in projector-type low beams but is not safe in most reflector-type low beams or in fog lamps of any type.
(End of Stern's answer).
Daniel Stern Lighting web site: http://www.danielsternlighting.com/home.html
NASIOC discussion and pictures: http://forums.nasioc.com/forums/showthread.php?t=2083911
