BrakeStrip Ensures Stopping Power
BrakeStrip™ is an easy to use copper brake fluid test that quickly and accurately informs the user if brake fluid needs to be replaced based upon the fluid’s copper level content; all in accordance with MAP guidelines.* This revolutionary product features Phoenix Systems’ patented FASCAR® technology that identifies the exact level of copper ions in brake fluid. Copper is an early sign of corrosion in a brake system. Without correction with new fluid, corrosion can be extremely damaging to a brake system, compromising the integrity and safety of your brakes.
To use: simply dip the BrakeStrip test strip in the fluid, shake off and wait 60 seconds. Then consult the color on the test strip with the FASCAR rating color chart that is included on each product package. If the test strip turns a deep purple color, matching the 200 rating level on the FASCAR rating chart, this corresponds to 200 ppm of copper, a level of copper that would require a brake fluid exchange.
BrakeStrip should be the first step in the preventative maintenance of your brake system, especially for costly ABS systems. Proven, risk-free, easy-to-store and use, this product is used nationwide by top brake service providers.
For the best possible preventative maintenance of any make and model brake system, trust the company that consistently advances brake test and tool technology – Phoenix Systems.
*The Motorist Assurance Program (MAP) has established copper as its recommended standard for monitoring brake fluid replacement at 200 ppm of copper. A FASCAR rating of 200 equals 200 ppm of copper. For more information, go to
www.motorist.org.
