1 - 6 of 6 Posts
so im trying to make a grill for my coupe but i see all these other posts of diy grills it has this outer trim to it. the 03 coupe is just this one peice in the middle and nothing else.. what should i do?
also, how different is the sedan grill from the coupe one?
is the sedan rear window the same as the coupes (rear window visor)
BRWNFLSH now
You are talking about the gutter guard grill application, right? If so, there is no opening on your grill, so you can't really do it on the upper grill. You could still do the lower grill to protect the condenser. The rear windows are also very different. Look at a couple pictures of the coupe and sedan, and you'll see what I mean.
i meant the rear windshield.. or w/e you want to call it. and do sedan grills fit coupes?
No lifetime fluids!
You could probably find a portable propane one but some of the larger models would probably be too big. Might be able to find a smaller charcoal one too.
so funny -.- :thumbsdow
No lifetime fluids!
You probably would be best served with gutter guard. Using tiny black zip ties, you probably wouldn't see the connecting spots where the material would over lap if even needed.
I don't know if the Odyssey grille would be large enough to trim to spec.
1 - 6 of 6 Posts
