+1.The front fender liner? It doesn't matter if you remove it or not, if you remove it, sure you can go down further, but the fender liner is higher than your actual fender so, if you can't clear the fender, why bother going lower?
Besides if you remove that liner, you are removing you protection from water and road debris getting in your headlight wiring and the sorts.
