I hit a small bird with my sideview mirror while on the highway. Ouch. The only damage was the outside plastic part cracked and the crack is push in a little. Can this be fixed or does the whole mirror need to be replaced? How much? Can this be fixed without taking it to a shop? Its a 2010 ex-l. Metallic gray color
hey...wassup:wave:
i had the same problem a few weeks ago (backed out of the garage, then hit the garage railing):headbash:. i had to replace the mirror and the housing. i bought the parts needed cheap and did it myself in 20 mins. (total $23) and picked it up from the dealership so i wouldnt be charged shipping. :thumbsup:
so yes. everything on there is replaceable. :yes:
From what I have read....you have cracked the "plastic part"=non-painted portion of the side mirror. Right?:scratch: Do you have any pics?
Go down to post #6 on this thread and use the pdf file. its what i used and it helped.
http://www.driveaccord.net/forums/sh...de+view+mirror
well, there you go. if you need any help, let me know (like ordering correct parts & where to order from), i can also help you step by step to fix it. (via webcam, etc..)
