1 - 18 of 18 Posts
Don't drink and drive
When I turn a full right to get out of the drive and let the wheel turn back to normal, during the last 25% of a turn back, there's a crunchy sound coming from the left side I believe. It sounds like a rusty bearing/joint that doesn't have grease to move freely. Maybe a control arm too?
The noise happens at low turning speeds, and maybe only 30 percent of the time.
I haven't taken the wheel or axle out yet. Just wondering if someone had a similar experience.
I had a metal scraping sound during low speed right turn, turned out to be the brake dust shield scraping against the brake rotor. It got bent when I did my last brake job. I just bent it back out.
Trying running the car on jack-stands and turning lock to lock. You might be able to pinpoint it.
I vote for the brake dust shield! Really easy fix!
I did that and heard nothing. Noise was only heard when the suspension was loaded and under stress. I suggesting bending the brake dust shield out another 2mm then the noise will go away.
Discussion Starter #7
So I took the wheels off tonight and also did what was mentioned above. Took it for a spin, same thing. I can feel the noise, crunch in my pedal and steering wheel. Not too bad but I can feel it. It feels like the serpentine belt is slipping. The arrow on the tensioner is to the right, which means it needs to be changed. My tensioner pulley is also shaking. I guess I'll take care of these two cheap, fixes since they need to be fixed, and see what we get.
I also experience this on my 06 l4 exl...seems like the car is straining especially noticable when backing out and turning the wheel almost the full way round. My PS fluid is clean and full and doesn't appear to be leaking or otherwise. I'm interested to see if your fix helps...I'm not wanting to unnessicarily change the tensioner though. thanks for sharing!
Discussion Starter #9
Let me know if you fix it before me and what you did. I'll do it within a month or so maybe.
Discussion Starter #10
Well, I got it fixed. My serpentine belt was too loose. After replacing it, the problem went away.
(I've never replaced the belt until now. :|)
That's good news that your problem is gone with a simple belt change! So you didn't need to change the auto tensioner as well?
Discussion Starter #12
Nope.
I replaced my belt but the problem still persists. The indicator is still to the right of the mark. I'm gonna look into tensioner pulley and see if it could be the issue
It turns out that my air intake breather tube was cracked and was causing my issue. It was sucking in air after the MAF sensor and causing it to get too lean...dropping RPMs low when idle or on the low end
I sucked it up and paid the dealer for a diagnostic while I was in getting recall service done on the airbag inflator.
Discussion Starter #17
I bet that sucked, money out of your pocket? They charged you what, $100?
1 - 18 of 18 Posts
