1 - 9 of 9 Posts
Cruisin Iowa...
Hello,
I have been unable to find where I dim the dash lights. I do a lot of night time driving. I'd rather ask you forum members than look through the 700 page manual :thmsup:
Thanks, Dan
JaeDM
you turn the dial on the cluster. It won't work till night time tho.
From the owners manual:
When the parking lights are turned on and the ignition switch is in ON (w*1, you can use the brightness control knob to adjust instrument panel brightness. Brighten: Turn the knob to the right.
Dim: Turn the knob to the left.
You will hear the beeper when the brightness reaches minimum or maximum. The information display will return to its original state several seconds after you adjust the brightness.
■ Brightness level indicator The brightness level is shown on the information display while you are adjusting it.
Instrument panel brightness varies, depending on whether the exterior lights are on or off. The instrument panel dims to reduce glare when they are on.
Pressing the (Select/Reset) knob switches the display.
If you turn the knob to the right until the brightness display is up to max, the beeper sounds. This cancels the reduced instrument panel brightness when the parking lights are on.
The brightness can be set differently for when the exterior lights are on, and when they are off.
my dim button is on the center console, top left corner above the cd input on the EX.
Button looks like a quarter moon.
I believe thats for the imid. Not the gauges.
1 - 9 of 9 Posts
