So this has now happened 3 times in the last few months, Once about a month ago and twice last week (after having the car dropped off to fix the brake TSB that causes a squeak on turns). I will be driving down the road from aggressive to normal driving and all of a sudden I look at my dash only to see all the warning lights on. Once this happens you can see the MPG indicator has a delay, LDW switch no longer functions, and LDW and FCW stop working. The car continues to drive but you can tell all electronics are experiencing a delay or issue with the exception of the Navi and Radio. Some of the lights go away and come back as you drive, and after turning the car on and off a few times all lights turn off with the exception of FCW and LDW with the "FCW System Failure" message which remain, that goes away after a few hours.
I have seen this topic circulate around a few times, one user I believe ended up changing a transmission, another user had his HIDs wired incorrectly. Im wondering if I just have a few error codes saved that need to be cleared, and how likely will the dealer try to blame this on the SRI. It just seems weird that its something that happens mid-drive, at least in my case.
