if your lights are off and you flash your high beams, only the high beams come on. the regular lights do not come on with the high beams.keywords, daytime, "on and off"
im refering to when u have ur lights to off position and u need to flash.
WRONG. when you flash your high beams in the daytime, the low beams come on too.if your lights are off and you flash your high beams, only the high beams come on. the regular lights do not come on with the high beams.
+1... Just train yourself to turn on your low beams, then flash away, wait a couple seconds until you think the HIDs have warmed up, and then turn them off...WRONG. when you flash your high beams in the daytime, the low beams come on too.
this is why i dont flash ppl in daytime because i have HIDs in my low beams. or what i would do is turn on HIDs first then flash.
+2 on that I have quad high beams 2 hid and 2 lows since I have bi-xenon projectors in the lows. I really dont like to flash people because it kills the life of the bulb and ballast if you turn it on and off really fast too much.WRONG. when you flash your high beams in the daytime, the low beams come on too.
I wonder if that would solve the issue if the lights turning on and off everytime you lock or unlock your doors, and also the slight on/off that happens when you start your engines with the lights on. I miss leaving my lights on after I leave my car and having them turn on with the car from far away.the only solution that i htought of i to convert the light stalk/control module to tl/tsx or put a relay timer.
Hmmm...do the HID's really blink when you lock and unlock your car? I thought only the corner lights do? Cant be good to have them blink every time you lock and unlock, talk about significantly lowering the life span!I wonder if that would solve the issue if the lights turning on and off everytime you lock or unlock your doors, and also the slight on/off that happens when you start your engines with the lights on. I miss leaving my lights on after I leave my car and having them turn on with the car from far away.
In a car like ours, yes, but they're supposed to be halogen headlights. Putting in HIDs doesn't change its behavior. Cars with HID from the factory like the TL are designed to not to turn on and off when lock/unlocking doors, or starting the engine.Hmmm...do the HID's really blink when you lock and unlock your car? I thought only the corner lights do? Cant be good to have them blink every time you lock and unlock, talk about significantly lowering the life span!
Wrong. Highs and lows come on at all times when attempting to flash/use highs... Alwayshmm interesting.. i THINK only my highs come on when i flash on off or parking lights. might have to check it out when i have time.
wrong too. The low beams dont "blink" when the car unlocks. If left on, the parking lights blink, and then in a couple seconds, the lows turn on. the turn off after about 20 seconds. Even TSX's with factory HID behave that way when you leave the lights on and turn the car off.In a car like ours, yes, but they're supposed to be halogen headlights. Putting in HIDs doesn't change its behavior. Cars with HID from the factory like the TL are designed to not to turn on and off when lock/unlocking doors, or starting the engine.
No, neither low nor high beams come on from locking/unlocking doors, try it, only the parking lights flash.In a car like ours, yes, but they're supposed to be halogen headlights. Putting in HIDs doesn't change its behavior. Cars with HID from the factory like the TL are designed to not to turn on and off when lock/unlocking doors, or starting the engine.
