201 - 220 of 307 Posts
Discussion Starter · #201 ·
So Dirty Girl has a small coolant leak somewhere. While I'm not 100% sure where, I know that it's coming from somewhere under the radiator cap area. I'm not sure if it's from the overflow tank hose, the tiniest of crack at the neck of the radiator cap, or if it's from a failed radiator cap.
I first took note that something was wrong when I made a lengthy trip through some of my local mountains and noticed that the engine temp shot up way above normal temp range. The AC was on and promptly turned it off, rolled down the windows, and turned up the heater. The temp then came back down back to normal. I drove it with low coolant for a few more days while I acquired more coolant and a proper coolant fill funnel that I'd ordered.
I picked this guy up and it worked perfectly. I had been using a small little funnel for all my previous radiator fills, that while worked, was quite messy. No more of that!
Since adding coolant, I have not driven anywhere since Thursday. I will monitor coolant levels over the next few weeks to see how fast they drop while I determine the exact location of the leak. If it's the hose itself, I'll just order a new hose from Honda, and probably also buy a hose clamp for added measures. If it's the cap, well, a new cap is in order. If it's the radiator, well, a new radiator is needed.
522389
522390
It's a bit hard to tell, but directly beneath the hose is a few drops worth of coolant spilled on the top of the radiator.
522391
If there's a leak you can usually smell it.
I once had the hot side plastic tank develop a very tiny crack in it where the plastic inlet (part that the hose clamps on to) molds to the tank itself. I kept losing tiny amounts of coolant. I could smell it but never see it. Finally one day I let the car run while I stood there staring at everything and eventually a drop formed from that crack. I'm not kidding. It would take minutes for the drop to start and minutes more for it to turn into an actual drop and then run down the tank. The fluid never made it to the floor.
I took it to a radiator repair shop and the guy told me that the hot side tanks do that a lot. He said he replaces many more hot side tanks than cold.
Discussion Starter · #203 ·
The last time I had coolant loss was when I replaced the leakless gasket....it's burried in this thread somewhere. It's the gasket #9 where the thermostat, temp sensors, etc. all attach to the coolant passage. It was a slow leak but fast enough where it allowed to pool up on the engine block externally directly below the gasket and it would burn off making a nice thick sticky mess. It was an easy find but not quite an easy fix. While at it, I also replaced gaskets #10, #18 (area I was working, not behind the water pump), and the thermostat. I remember having to add coolant at least once a week before finally fixing it. If anyone has to replace that gasket, be sure to do the EGR passage cleaning on the intake manifold. Having all this removed also allows one the opportunity to clean out (or at least inspect) the EGR passage on the lower port as well.
The time before that when I had significant coolant loss, was my radiator. It had a nice long crack going the length of the radiator about 6" on the plastic below the radiator cap. That was an easy find and easy fix.
522439
Reactions: enne
Discussion Starter · #204 ·
The PS pump of Dirty Girl is doing something weird. I'm unsure if it's an issue with the pulley or if it's the bearings inside the pump. My guess it's the bearings inside the pump.
How long has it been doing this noise for? Well, I took the video on June 29. The noise had started a few days before that
I clicked your YouTube video and it brought me to another video of yours. Did you ever find out what the odd noise was coming from your dash? My car does the exact same thing!
Discussion Starter · #206 ·
Yeah, I have a few videos.
No, I've never found the source of the noise. My car still has the noise. I've asked some people as to their thoughts on the noise, and they say it may be the HVAC blower motor. Then I stump them when I say that it makes the noise still when I have all HVAC controls turned off.
Did you find your coolant leak?
Discussion Starter · #208 ·
I believe it's the small hose from the radiator to the overflow container. The radiator gave up on me a few weeks back, so I'm going to monitor the levels of the coolant and see if it was that instead of the hose.
When I drained the radiator, I only managed to drain about 1/4gal. The coolant system has about 2gal capacity and I filled up about 1-3/4gal.
525233
525234
525235
Discussion Starter · #209 ·
Because I'm an idiot, Dirty Girl got new battery terminals.
525317
525316
Discussion Starter · #210 ·
Looks like Dirty Girl needs a new IAC valve.
526547
07V6 EX-L Chicago
I'm pretty sure it's one of the A/C and heater air blend door actuators, not blower motor. The actuator keeps moving back and forth trying to find the perfect rest position, but due to wear/contamination of the resistance tracks, it could not.
If you are lucky, take it out, clean and re-grease would solve the problem. Or you may need a new actuator.
Discussion Starter · #212 ·
This makes sense!
I've had confirmed issues with my blend door actuator before where I would switch between various positions and it wouldn't move from the existing position. Then several minutes later it would actually move and it would cycle through all the positions I had been toggling through.
Where is the blend door on the 6GA? Is it easy to get to or do I gotta tear apart the dashboard?
While I'm working on that, I would also replace the blower motor because now it is giving me issues. It does this awful ticking noise and the noise increase / decreases as I move the fan speed up / down, and completely goes away if I turn off the HVAC system.
one wheel drive
My friend's 03 TL blower was vibrating so I took it off and cleaned the fan. Its like a hamster wheel and was partly crapped up with you name it. I haven't taken out my Accord blower but think it would be just as easy and maybe you can flush out some twigs or needles making the noise instead of forking out for a new one.
Discussion Starter · #214 ·
How is the blower motor removed? And how is the blend door actuator removed?
one wheel drive
It should be just 3 screws holding it in under the glovebox. The blend door stuff I've never had to mess with, sorry dude.
Discussion Starter · #216 ·
Would it be found during the cabin filter replacement procedure? With you saying what you're saying, I couldn't imagine it being very far off from that process.
Sent from my Pixel 3 XL using Tapatalk
Pilot without a plane
I had the mode control motor go bad on mine. I pulled that and the blend door actuators out of a junkyard car. There are pics in my car's thread. Hopefully that will help you.
Discussion Starter · #219 ·
Thanks guys. I'll take a look at it this weekend
Reactions: TX Accord
2010 2.4EX
I'm finally giving Dirty Girl the TLC she needs, and she's not AS dirty anymore! So, I figured, why not make a thread for her? :)
I installed a lot of what is in this box, and more needs to get installed still.
Driver side spray nozzle
It's hard to see, but you can see the hyper extension of the wiper blades as well as the poor contact quality of the old wiper blades on the glass
Before vacuuming
After vacuuming
This heffer was $150 over on Honda Parts Cheap as I couldn't find an aftermarket unit for Coupe. Though, aftermarket sedan units were readily available for around $70.
Normally, wiper blades aren't a very special item, but my old blades were something like 4yrs old so the new blades are a special item to me, LOL.
Yes, I painted the wiper blade arms!
New spray nozzles! On the old one closest to us, you can make out a blueish-white dot in the middle of the spray nozzle. That little guy made the spray ineffective and eventually caused the buildup in the other picture seen above
And the new wipers fully installed and properly aligned. It took me a little bit to get them aligned properly. I love the fact that when I use the wipers now, they don't hit the A-pillar nor the bottom splash guard
Nice work, and classic Accord! From the common-sense era.
What is in photograph #10 - wiper motors?
