1 - 12 of 12 Posts
Premium Member
Not a big deal, but I'd rather they looked new if I could help it. Brakes are fine, but rotors look like crap. I've read a few threads but got no definitive answer. Do I just have to live with this on Accords? My rotors always ended up looking like this regardless of brand. Never on other cars though. Always looked like new. Has anyone had success with different rotor pad combo? These are Raybestos rotors with Duralast Ceramic Max pads. They're not ridged, just look like it. Rotor is still smooth.
RacerRik
That rotor looks great! Seriously - that looks like a typical rotor that is performing the way it is designed to perform. Leave it alone and just enjoy your car.
If you want a mirror finish, look for really light performing ceramic pads. If you want braking power, then semi-metallic or metallic pads with tons of dust and eat into rotors. I prefer the latter, they are brakes! Or you can wait until Tesla comes out with some magnetic ones that reverse magnetic polarity when pedal is pressed, much like how bullet trains stop...... that's many years away? Brake technology has not changed for about 100 years. You can keep the rotors relative smooth as long as you lube the slider pins so the caliper bracket closes in evenly top and bottom.
Moderator
put new rotors on and don't drive it. ever.
problem solved.
Unless he lives in Arizona or some other similarly dry place, Otherwise OP will get "lot rot" - the rotors will rust from atmospheric water.
BRWNFLSH now
Do you live in an area where there is a lot of dirt/sand? Drive on dirt/gravel roads? Just looking for contributing factors here. I have Raybestos (NAPA) rotors, with Honda pads, and they do look cleaner than that. Looks like it could be just a little rust from rain earlier in the day if you haven't used the brakes much since. If there are no deep grooves, that will catch a fingernail, I'd say it's nothing serious.
Premium Member
Discussion Starter #7
I live in SW Florida. Quite humid. Things do tend to rust here.
Just don't go look under the car or the door hinge bolts.. you'll have an ulcer
Premium Member
Discussion Starter #9
Pardon me sir, but my door hinge bolts are spotless. As are my strut bolts and wheel wells. The frame is not visible so I don't obsess over it. I dislike rust and am constantly Dremeling something or other. Damn humidity in SW Florida. Finish with a light coat of Boeshield T9 and you're good to go.
IMO, rust is a sign of a neglected car. Just my opinion. That's why I asked about the rotors in another post. Whenever I replace a caliper, I coat it. Tends to keep the rust at bay.
You can't avoid rust, unless you live in an area devoid of humidity and water like California. or in a desert. But they have a whole other set of problem because of water shortage.
Premium Member
Discussion Starter #11
True dat. And wildfires, and earthquakes, and ridiculous gun control laws. I can deal with a little rust in the Gunshine state.
I know what you mean. Rotors on other cars in my area seem to be smooth with no circular marks/scratches. My rear rotors also have random rust patches even though they work fine.
1 - 12 of 12 Posts
