Do you have a relay harness...could that be the problem?Well I still start.
55w 6000 Digital set
only my right light will come right now. had set only for 6 months
Doubtful. It worked fine for 6 months. If a lack of harness was the problem it wouldn't have worked fine for this amount of time.Do you have a relay harness...could that be the problem?
Have you tried taking your driver side hid bulb and putting it into passenger side and seeing if it works. If it doesn't you likely need a new bulb. Then I would try taking the bulb from the side that does work and move to the side that doesn't, if the bulb won't fire up, you need a new ballast. Either one I believe is covered under warranty, have you contacted retrosolutions directly?Well I still start.
I had called them and even got the RMA but I tried the above and it worked.Have you tried taking your driver side hid bulb and putting it into passenger side and seeing if it works. If it doesn't you likely need a new bulb. Then I would try taking the bulb from the side that does work and move to the side that doesn't, if the bulb won't fire up, you need a new ballast. Either one I believe is covered under warranty, have you contacted retrosolutions directly?
I've had over a dozen 55w DIGITAL kits from Todd, never had any serious issues. Have you talked to Todd? Hes extremely helpful and the kits are lifetime warrantied...I have a relay harness and a time delay. I think the 55w are just bad from them.
Must have been a user error? Between me and my friends I've gotten probably 13-15 kits from Todd. I've had I think 2 bulb failures and both kits were over a year old. Bulbs were replaced and everyone was happy.I have both the variable 35/55 watt kit (installed in two diff cars) and 55 watt kit from them. They both ****s. Work fine for an avg of about 6 months then it all goes down hill from there. No problem with my xenon depot kit.
You can't access the HID's through behind the fender liner?I've had my kit for about a year and i just noticed that one bulb looks like a 4k bulb while my other one is fine its 6k. I already contacted retro and i gotta go try some different things to fix it. I realllly didn't want to have to take of my front bumper ever. Thats why i got my HID professionally installed for me...
