thanks, I was hoping I could do a wiring mod to have them light.Those buttons dont light up the only light is from the bluetooth mic.
Thanks a lot for helping and turning your lights on / off to verify. The dots look like painted dots. I will take a photo a little later and attach it to the thread. I hope it is the same as yours. I think it is because the moon roof controller also looks like they are painted and they light. I will also take it out again to see if the connector has a line for the lights. Thanks again.I checked mine today on my V6 and can say that they definately light up. The 3 buttons, each with a "dot", 1 dot, then 2, then 3, each light up when the headlamp switch is turned on. I turned the lights on and off to be sure and there was no reflection. It is bright and obvious when you turn off the headlamps. These buttons light up on my car. I don't use homelink and have never touched it but they are indeed illuminated.
The first photo is of the buttons. They look like they are just have painted dots but several V6 owners report they light up. (Thanks again for the info).Thanks a lot for helping and turning your lights on / off to verify. The dots look like painted dots. I will take a photo a little later and attach it to the thread. I hope it is the same as yours. I think it is because the moon roof controller also looks like they are painted and they light. I will also take it out again to see if the connector has a line for the lights. Thanks again.![]()
Yes, it can be done. I got a wiring diagram for the 2012. The 2013 may or not be the same. Anyway, i dont have the time now but maybe in the spring. In the mean time, if anybody has the wiring diagrams for the 2013, please post it or send me a PM.Good info. Thinking about purchasing the same unit from college hill but do not want to remove the overhead counsel to replace the battery and I want them illuminated. Did any body determine how to wire direct. Post pics if you did. Thanks.
Buttons light up - homelink works with car off. I typ open garage door before turning on car. Note that when I get in the car (open door).. I have the dome/hl/tail come on, so I don't know if that "triggers" the homelink for use.I forgot to check to see if the Homelink works when the car is off. Will check it tomorrow morning
