1 - 5 of 5 Posts
I was wondering if anyone has had any issues with these. I have a sedan and when i open the doors, only the rear dome light illuminates. It looks like it works properly, fades out etc. the front lights both work if you click them, just not when the doors open. every now and then I can wiggle the lights up front and the passenger light will work and fade out when the doors close, but whatever was loose I think has finally broke.
Anyone know offhand how all that is wired? Can I get a full overhead light replacement if needed?
Thanks
there was an easier way to do this...you just connect a wire from the dome lights to a port that is empty in the map lights. There's a diy somewhere on the forums
Thanks, hope the 2008 is the same.
It is the same as well as Acura's, I had the same issue on a 2005 Acura TSX and this procedure fixed the issue. I can not see how running a wire from the back dome light is easier?
1 - 5 of 5 Posts
