1 - 4 of 4 Posts
6th Gear
I have a 2006 honda accord sedan v6 and the left low beam and high beam don't work. The turn signal "somewhat" works but it is very dim. I believe it's a loose ground, possibly knocked loose when I changed the battery a few days before. Headlights worked ok, but stopped workign a few days afterwards.
Checked fuses, all good. I think it's the ground? Any diagram or any help would be much appreciated.
That's odd its only the left side. I would check that all the wiring is secure on the left side harnesses going to the bulbs.
I would think a loose ground might cause both headlights to act equally funky, but since its only the left side, I figure you might start by checking that side thoroughly first.
Glad you got it fixed, thanks for the update. Makes it easier to search for solutions.
1 - 4 of 4 Posts
