I've used Akebono ProAct Ceramic Pads for a long time, but they were out of stock when I had to replace the fronts on the 07 so I went with the EBC Redstuff, based in large part on the good reports on here and many reviews citing low noise. I installed them in late November, 2013, on my wife's DD. Since then, she's put about 15,000 miles on the car, mostly commuting on the interstate, and she is "spirited" in her driving style.
Recently she began complaining about loud, embarrassing noises (from the car) when braking. It happens at low speed and sounds like some rotating parts are interfering when the pedal is applied. It was clear the fronts were at fault. I did a quick inspection and found plenty of pad (>50%) and no uneven wear. Investigating further, I removed the two screws holding the caliper and lifted it easily off the bracket - no evidence of a frozen caliper.
As soon as I did that the shim on the inboard pad fell to the ground, The pad was so badly corroded the shim was unattached. The same thing happened when I checked the other front corner.
While I think I found the cause, needless to say I am very disappointed in the lack of durability. I'm doubly disappointed because the pads have been very well behaved otherwise. I might even prefer them to the Akebonos, until this.
When I replace the pads, I 'll post pics.
I'm also complaining to EBC and I'll report back on any response.
Has anyone else experienced this? I have not, in over thirty years of northern winters with at least two cars on the road.
