1 - 2 of 2 Posts
03 V6 coupe auto
I threw code p2195 last night and found the TSB regarding the ECU update required to fix the problem. The TSB mentions that out of warranty claims may be eligible for goodwill consideration. Has anyone had these performed out of warranty and had Honda cover it?
It would seem that since this is not a wear item, and honda has acknowledged its a software issue, it should be covered.
Also, how do I find out what the latest updates are for the ecu and trans.
Stayin Classy...
1. Just to clarify, what is the P2195 cord mean?
2. If the TSB is related to your code, then it should be covered. TSB's mean that honda accepts there is a problem, but its not sever enough to issue a recall. So you have to come to honda with symptoms, and they will fix it for free no matter how old (usually).
3. What car model do you have?
You can most likely call corporate and see if there are any TSB's related to your VIN number and confirm if any of them are directly related to the code your getting.
Good luck
1 - 2 of 2 Posts
