1 - 2 of 2 Posts
Eibach suspension springs and components are engineered to meet the extreme requirements of racing, from the 245-mph Mulsanne straight of Le Mans to the fender-to-fender combat of the Daytona Motor Speedway.
The chassis of a street vehicle is designed to be built at a minimum cost, and suited for an "average driver". We enthusiasts, however, are anything but average. We know what we want from a vehicle. We want immediate response, reduced body roll, increased stability and enhanced cornering ability. And we want the look that comes with those characteristics---a lower, more muscular, more athletic stance.
The special skills of Eibach engineers are in the tuning of the individual components (springs, shocks and sway bars) to achieve the best possible harmony between the driver, the automobile and the road. As a driver you immediately feel more direct handling and greater predictability. Nose dive under braking is reduced, as well as excessive body roll in hard cornering. In any performance driving situation, tracking stability--and driver confidence--is greatly enhanced. Lowering your vehicle has one more additional benefit that we learned from all the race teams we work with and independent testing: reduced wind resistance. This allows for higher top speeds on the race track and better fuel efficiency on the street! See for yourself: check out how the average car or truck can be transformed with the installation of an Eibach suspension system.
Eibach regards Motorsports as the ideal proving ground. The experience we gain at the highest levels of racing is directly converted into the development of the highest-grade chassis components on the planet. And the enthusiasm created by the challenges of motorsports drives us to ever-higher performance---performance that you will enjoy every time you drive.
Made in Germany and the USA
1990-1997 - Pro-Kit (Performance Lowering Springs - Set of 4) -
1998-2002 - Pro-Kit (Performance Lowering Springs - Set of 4) - including Type S
1998-2002 - Pro-Kit (Performance Lowering Springs - Set of 4) - 2 & 4-door including EX 4Cyl
2003-2005 - Pro-Kit (Performance Lowering Springs - Set of 4) - 3.2L V6 excluding Type-S
2003-2007 - Pro-Kit (Performance Lowering Springs - Set of 4) -
2008-2011 - Pro-Kit (Performance Lowering Springs - Set of 4) - 2.4L I4 excluding Turbodiesel CU2
2008-2011 - Pro-Kit (Performance Lowering Springs - Set of 4) - 4-door excluding Hybrid 3.5L V6
2008-2011 - Pro-Kit (Performance Lowering Springs - Set of 4) - 2-door 3.5L V6
1990-1997 - Sportline Kit (Extreme Lowering Springs - Set of 4) -
1998-2002 - Sportline Kit (Extreme Lowering Springs - Set of 4) - 2 & 4-door including EX 4Cyl
2003-2005 - Sportline Kit (Extreme Lowering Springs - Set of 4) - 2 & 4-door excluding Hybrid 3.0L V6
2003-2007 - Sportline Kit (Extreme Lowering Springs - Set of 4) -
2008-2011 - Sportline Kit (Extreme Lowering Springs - Set of 4) - 2 & 4-door 2.4L I4
1998-2002 - Anti-Roll Bar Kit - FRONT - including Type S
1998-2002 - Anti-Roll Bar Kit - FRONT & REAR - including Type S
1998-2002 - Anti-Roll Bar Kit - REAR - including Type S
1998-2002 - Pro-Damper Kit (Set of 4 Performance Shocks) - including Type S
1998-2002 - Pro-Plus Kit (Pro-Kit Springs & Anti-Roll-Kit Sway Bars) - including Type S
1998-2002 - Pro-Plus Kit (Pro-Kit Springs & Anti-Roll-Kit Sway Bars) - 2 & 4-door including EX 4Cyl
2003-2005 - Pro-Street-S Kit (Height Adjustable Only Coil Overs) - 3.2L V6 excluding Type-S
1998-2002 - Pro-System Kit (Pro-Kit Springs & Pro-Damper Shocks) - including Type S
1998-2002 - Pro-System Kit (Pro-Kit Springs & Pro-Damper Shocks) - 2 & 4-door including EX 4Cyl
1998-2002 - Pro-System-Plus Kit (Pro-Kit, Prp-Damper Kit & Anti-Roll Kit) - including Type S
1998-2002 - Pro-System-Plus Kit (Pro-Kit, Prp-Damper Kit & Anti-Roll Kit) - 2 & 4-door including EX 4Cyl
1998-2002 - Sport System Plus (Sportline Kit, Pro-Damper Kit & Anti Roll Kit) - 2 & 4-door including EX 4Cyl
1998-2002 - Sport-Plus Kit (Sportline Springs & Anti-Roll-Kit Sway Bars) - 2 & 4-door including EX 4Cyl
1998-2002 - Sport-System Kit (Sportline Springs & Pro-Damper Shocks) - 2 & 4-door including EX 4Cyl
GO TO NOPI EIBACH Catalog for more specific details
Contact the salesmen below or PM me for our best deal on Eibach
1 - 2 of 2 Posts
