1 - 15 of 15 Posts
Premium Member
New issue with the car, the other day the car threw p0685. But i have no performance related issues along with that code like many did. What i do have is as you turn the key from position II to position I the car loses all electrical power, to the point that the nav system makes me re enter the code but doesnt wipe the stereo presets, its sort of a split second total power loss. It only does this occasionally though and i cant predict when. The instrument cluster loses all power at the same time as the nav system, so i dont think its something tripping the starter cut relay.
Im assuming theres a sticking relay somewhere, just ordered replacements for both of the ECM relays in the interior fuse panel. Spent a few hours looking over the ETM and couldnt find a relay or circuit that could cause a total power loss. Both battery cables are clean and secure on the terminals. g101 is fine too.
BRWNFLSH now
Elvira
Can you get the engine to shut off by simply wiggling the key in position 2?
Wouldn't a faulty ignition switch cause an open in that circuit?
I have no schematic but those recalled switches back then would remove voltage from the system and shut an engine off.
Premium Member
Discussion Starter #4
Engine stays running wiggling the key, no open recalls on the car and never had a recall on the ignition switch.
I'll take a look at the Ecu fuses
Premium Member
Discussion Starter #5
Another oddity, plugged my scanner back in and there were no codes in the computer, but I never cleared them and normally my scanner can still read inactive prior codes that weren't cleared but the p0685 isn't there
Premium Member
Discussion Starter #6
Im giving up, the split second total power loss is now up to 5+ seconds, cant find any evidence as to why. Car goes to the dealer tomorrow.
Of course while running a few errands today it didnt have a single issue
Roll Tide!
I sure hope your gremlin isn't a smoker....
@enne told me, @qman , @salcuta88 , @Coach Steve , and @RickBlaine one time [at band camp] that it's not easy to expose gremlins, but when they are exposed, you should be very thankful and be prepared to throw a lot of money at it.
Runnin' in the 90s
So what you're saying is, I should've named my car Gizmo...
Reactions: ethlar
Premium Member
Discussion Starter #12
I know this is old, however did you ever figure out the problem?
i wound up swapping one of the ECU/ignition related relays in the under dash panel and that seemed to resolve it for a while, but it did recently happen again without setting any engine codes. Im starting to wonder if it could be a bad contact on the ignition switch itself.
Reflections Auto Detail
My second car was a 1973 Gremlin with a 304 V8 that would keep up with almost anything out there at the time - off the line of course. That short wheelbase mixed with the 304ci engine made for an unassuming little rocket off the line!
The car was painted (and I swear I'm not making this up...) Electric Green Metallic! Make no mistake, it was hideous! It had those ever popular vinyl seats that would scald you on a hot day if you were wearing shorts. Ahhhh... good times! :wink:laugh
Reactions: jimijam and ethlar
Runnin' in the 90s
So your car was literally an electric[al] gremlin? lol
Reactions: jimijam
Old Bird...sometimes wise
I had a friend with one of those and the same color. His had some black accent decals on it and would light up the tires, well the right rear, with that 4 speed stick. Scary in corners though....swapped ends quickly with that short wheelbase.
1 - 15 of 15 Posts
