1 - 2 of 2 Posts
I have a intermittent issue, when I turn on my High beams I some time lose power and if I am at a stop and turn on high beams the car stales. This does not happen all the time but now when it happened I got a P0685 code .
2003 Accord EX 6 Cyl
any ideas?
· Ballin' on a budget
Could be a faulty healight relay and or fuse. Check those first, if not see the thread below for some additional info.
http://www.driveaccord.net/forums/showthread.php?t=65736
P0685 ECM/PCM Power Relay Control Circuit Malfunction
- ECM power control circuit is open or shorted
- Failed ECM power relay
- Failed ECM
If its not the ecu, as it's been replaced, it's likely the relay where the issue lies.
also, check your battery terminals and connections. a lose feed line could cause power issues.
1 - 2 of 2 Posts
