41 - 48 of 48 Posts
2005 Accord EX 4cyl
Discussion Starter #41
20 days and 600Km after, checked the dipstick.
525746
Red line was where it was when I've added 900ml(+150ml of MMO)
So it's burning damn fast, I think. I just added another 900ml of SuperTech 0W20.
I can't find the time to do the soaking method because of god damn work shift giving me no day off.
Elvira
The MMO is probably whats burning off so quick.
Reactions: KW2004Accord
2005 Accord EX 4cyl
Discussion Starter #43
Even putting that into consideration, wouldn't the consumption rate be quicker than normal?
At this point, I'm worried if my engine is going to be okay... and I don't have the budget to move on to next car. :(
Stop worrying, your engine is going to be OK, just keep checking the oil level. Ever change the PCV valve ?
2005 Accord EX 4cyl
Discussion Starter #45
Yes, I changed it around the time I added oil- 20 days ago.
So engine oil burning won’t damage the engine? Should I just keep adding/changing oil as it goes?
Many here have oil usage, mostly on the 4 cylinder because of the way the rings were mfg. A few have gotten the engine to stop consuming oil by using the piston soak method, but usually it just slows the consumption down. Honda says using a qt. of oil every 1,000 miles is considered normal. I put in a qt. every 900 miles. Just keep adding / changing (low / dirty oil can stretch the timing chain & wear the guides).
Premium Member
Give Lucas Synthetic Oil Stabilizer a try. You add 20% of the volume of your crankcase, or a little less than a quart. Wait until the next oil change to try it.
It helped my '06 reduce its consumption quite a bit. Didn't think it would work, but it did.
Accord fan
Have you checked the spark plug tube seals? The oil consumption on my 4 cylinder slowed up quite a bit after I replaced the broken seals.
Sent from my SM-N950U1 using Tapatalk
41 - 48 of 48 Posts
