1 - 17 of 17 Posts
Any V6 owners hearing a high pitch whine or ringing noise on the hwy under light throttle conditions or slight down hill grades? Noise goes away when throttle is pressed down or engine loads up. Only comes on in 6th gear.
9300 miles on the car. Had it in the dealership and they heard the noise but say its normal but said they would leave the case open just in case Honda comes up with something. Never had a car make this noise before. Ruining an otherwise good experience.
Thanks
DT
Rhymes with Mick & Quick
Definitely not normal - I have never heard such sound in my V6. Get it looked at again, and if they tell you that is normal, go find another dealer.
Mick
Noise only comes on when under light engine load such as a flat road or slight downhill grade. Basically a lot of Hwy conditions. You can tell the right conditions when the mpg gauge goes all the way to 60mpg or close to it. Its very predictable. Light throttle pressure to hold speed and the noise just comes on. Push on the throttle or let up and it goes away. Thinking a diff gear noise of some type.
Let me know if you guys can replicate.
Thanks
DT
2013 OBP Sedan EXL V6 Nav
Not here. (Other tranny issues though discussed elsewhere)
Discussion Starter · #10 ·
Thanks. Sounds like a diff issue under light throttle..can be very annoying at times and out of place in such a nice car. I will give it some more time and see what happens.
2014 Accord V6 Touring
Bringing this back up as I still hear this noise. Curious to see if more V6 owners picked up on it??
Thanks
i don't hear anything like that. i only hear a slight rumble or vibration when the cylinders shut down when on a load. 200 miles
people who don't hear it probably don't know what to listen for. you are probably hearing air turbulence through the intake system and throttle body(which is normal) or even the throttle body itself.
turn the ignition switch on but leave the car off. then lightly apply the throttle and see if the throttle body itself is the noise (which is normal)
coming from my lemon altima i listened for anything on my extended test drives in the i4 and v6. I hit the highway, accelerated hard and soft with windows up and down with the radio off. Car is solid, haven't heard anything unusual.
Discussion Starter · #15 ·
Wow, i did hear the throttle body whinning/ringing when i tried this. Very obvious noise. Wonder if mine is louder than normal? Will have it checked out.
Thanks for the advice!
DT
I did hear exactly the same "turbo" whistle in my previous hybrid Accord at times. Did not hear this whistle from my current Accord yet.
Discussion Starter · #17 ·
I believe the noise I am hearing is mechanical (gears) or servo (throttle body). Turn car on but do not start, turn off all fans/radio/etc, press on throttle and listen for throttle body servo noise. I heard it pretty easily. Wonder if V6 TB only?
1 - 17 of 17 Posts
