2013 Accord I4 EX-L
I've never had a Honda that has oil loss until this car, but this car started around 60k(currently have around 120k), so I was tracking the loss. Since 60k it's been about 1 quart every 3k miles. Recently I was reading people saying that a bad PCV valve can cause oil loss - so about 2 weeks ago I replaced the PCV valve and serpentine belt(both were the originals for the car). Both the belt and the PCV were Honda parts. At about the same time I also replaced the tires. Since then I've seen the oil loss go up significantly(1 qt per 500 miles) and my MPG go down by about 10%. The reason I mentioned the tires is because that could be to blame for the MPG. I looked around the engine and under the car and don't see any oil leaks, so I'm guessing it's being burned.
Today I switched back to the old PCV valve since I still had it, to see if the oil loss would decrease again, but I obviously need to wait a week or so to see. Anyone have any thoughts? Probably bad PCV valve?
Thanks!
Thanks!
