1 - 4 of 4 Posts
i have a 90 accord lx with a f22a1 is it worth it to put the f22a6 in it or just put another a1 back in it
RIP my Acorn
You might as well go with another A1 since the A6 will require a new ECU. Unless you find a cheap A6 and PT6 ECU and know how to swap ECUs, your best bet is the A1.
i know how to do all the work im just would like to know if the a6 would be better than the a1
is the wireing the same on an a6 as a1 is what im relly trying to find out and would it give me some more power
wiring should be the same think the only difference if im not mistaken is the intake manifold, exhaust manifold and a slightly bigger cam so all the good stuff is in the head; blocks should be identical. and as mentioned by CM6 you will need the other ECU which like he said is the PT6...
CM6, Seems to me like you know these CB7's very well probably my fav car still have my coupe if i ever get rid of it i would replace it with another CB7 lol:thumbsup:
1 - 4 of 4 Posts
