1 - 3 of 3 Posts
Hi
My car is a 2007 and has Nav. And it's gone bad. I have a non Nav. Factory radio with dual climate controls. Will this work with no problems?
Thank you
Should work, I went from a 2005 EXl without navi to navi, I used the nav system designed for the 2006-07 Models. I have put my original radio back in just to try it and it worked fine. You will lose your upper dash panel clock temp display, since the nav system has the connector that runs the upper dash panel,the standard dual climate control radio has all that built in. So in all there should be 2 connectors you will not use, the nav connector, and the upper dash display connector .
I think you will be fine to do that swap.
1 - 3 of 3 Posts
