Hi,
Does anyone have a radio wiring diagram for 2010 Honda Accord EX-L with navigation? I searched everywhere, but the only diagram I found was for a Civic.
I installed an aftermarket android head unit using a Metra wiring harness. The crimps are not fully installed in the harness, so I lost power to some. For example, I lost connection to the steering wheel control. Hence, I want to tap the steering wheel control wire directly to regain control.
I used Metra 70-1729 harness to power the head unit. As you can see, it doesn't have all 24 crimps.
Metra has a female wire harness as well. They tell you what each pin is used for.
According to the chart above, pin #9 is Audio Remote Switch. Hence, I wired the head unit's steer wheel control wire directly to the pink wire (pin #9 in the factory radio wire), but it doesn't work. Do I need to buy a special device to use the steering wheel control?
Thanks,
Thanks,
