Good morning.
I have a 01 Accord EX V6 auto.
Today while driving into work, I got a P0116 code. "Engine Coolant Temperature Sensor Circuit Range/Performance Problem.”
This morning the outside air temp was 15 degrees F.
So, it was dam cold out... Could that cause this fault sometimes?
Reason why I ask is because, Last year in (April 2021) I had a stuck closed thermostat (the original Honda thermostat from 2001 still which I though was impressive). I then Replaced it with a Failsafe 7302-170 , and a new Duralast Coolant temp sensor. SU4006.
Since they were original to the car from 2001. I Have not had any issues till today...
Debating if I should go with a new set of Honda parts and eliminate any aftermarket potential of issues, or am i just being worried for no reason?
*Found these on hondapartsnow.com
Part Description:
Part No.: 19301-P8C-A11
Thermostat Assy. (NIPPON THERMOSTAT)
$45.02
Part No.: 37870-PK2-015
Sensor Assy., Water Temperature (HADSYS)
$60.20
Part Description:
$45.02
$60.20
