Hello,
I have a 2009 Acura TL and I want to put a subwoofer in it. I have a 500W speaker at 2 ohm, an Alpine MRP-M500 mono amp, and an Audio Control LC2i.
Will an 8ga power wire (required by this version amp) be enough to run the amp and the LC2i? I'm assuming the LC2i will not need much power. I want to run the power wire all the way to the back and then put a distribution block to go into the LC2i. I believe it needs a 12ga power and ground.
Thanks for any help.
