Just noticed today that my rear passenger window "chrome" trim is coming off slightly in the back. Is there a fix for this, or a way to replace the whole thing? I'm not even sure how this would come off like this.
Looked kind of bent to me also like someone tried to pull it off. Did BLCKFLSH say how to replace them? I didn't notice it before, but now that I know its there its all I can see.Looks bent to me, not just the adhesive wearing off... But it can probably be stuck back down with more adhesive.
BLCKFLSH posted this not too long ago
"From what the service manual says, if you remove the moldings you will have to replace them. I guess you can't remove them without screwing them up. And I checked the prices and it would cost a butt load of $$$ to replace all of them, especially if you have a 4 door."
That not a bad price, I was expecting more. For removing it I bet princess has a pdf out here somewhere, if not there are a lot of Honda Techs on the forum that can probably help you. HondaTechAV6 is one but he only gets on once a week or so.Looking at majestic honda I don't see the part I would need. Anyone know?
http://www.hondaautomotiveparts.com...ORD&catcgry2=2006&catcgry3=4DR+EX+(V6)&catcgry4=KA6MT&catcgry5=REAR+DOOR+PANELS
EDIT:
Found the right section called Moulding.
http://www.hondaautomotiveparts.com...cgry1=ACCORD&catcgry2=2006&catcgry3=4DR+EX+(V6)&catcgry4=KA6MT&catcgry5=MOLDING
Now gotta figure out how they come off.
There is a screw holding the molding on the front edge, and there should be a clip at the end where it is loose. Do you see a clip pointing down near the loose end? If you push the molding down will it not stay down? If not, you might have to buy a new molding. I've never taken one off, and the service manual also says to remove the door panel first. The manual says you will bend the molding when you remove it. Good luck
