1 - 20 of 37 Posts
2008 ex-l v6. When I came to a stop light, after about a 1.5 hr trip, my car starts to sound rough. I put the car in neutral to see if I could hear any other noises and look at the lights on the dash. I see the check engine light flashing. I searched google and see this is surely a misfire. I read that there are two types of misfire. Type a and type b. type a is serious and talks about doing mechanical damage.are there two types of misfires?
Btw, if it a misfire and cylinder 2, this will be the second time in 15000 miles!
flashing MIL is a catalyst damaging misfire and need immediate attention. Congratulations, your about to get yourself 3-4 new sets of piston rings! or at least start with four plugs and a software update.
have you had to update done?
Ouch! Doesn't sound good :(
I started to drive to the local advanced auto and have them hook a code reader up to get the code but before I did, I called one of my mechanics. He says do not drive it any more than you have to. Not even less than 10 miles to get the code. He also said it is not a question of how long it continues to run but that it will quit at some point. I assume you mean catalytic converter when you said catalyst? I had to replace a catalytic converter on my last honda accord (2003) and it was only a piece of pipe with a filter in it? Maybe the one in the 2008 is different but how can it damage a piece of pipe and a filter? Maybe there is more than one catalytic converter on this 2008; I will google that too.
Last time I had it in for repair, they said all the updates were done. Is there a specific update for this issue?
your technician was right, driving with a flashing check engine light is certainly bad for the car. A flashing light, means that 1 or more of the engines cylinders is misfiring. This means that the air and fuel being introduced to one of the cylinders is not completing a burn/combustion on its power stroke. as a result raw fuel and oxygen is then expelled out of the cylinder via exhaust valves into the exhaust.
A catalyst is a substance that increases the rate of a chemical reaction without undergoing any permanent chemical changes itself.
Your catalytic converter uses certain elements (iridium, rhodium, platinum, ect) to convert harmful combustion emissions into safe molecules. For example HC, CO, Oxides of Nitrogen are the harmful ones. The catalyst separates the molecules HC's, CO, and No2 and converts them into CO2, H20, N. This is why you see water dripping out of a tailpipe, and why hippies cry about idling cars and greenhouse gas. (CO2) LOL. I can't speak intelligently about the details of the reaction and its chemistry, but a result of the chemical reaction is heat. these converters can reach 1800 degrees F.
When you have a misfire, you not only emit un burned fuel (HC) down the pipe, but oxygen. whenever you add O2 to a high heat, volatile condition, more heat/energy skyrockets. The excessive heat will damage the elements within your cat.
As you can see, you cat isnt simply a pipe with a filter. If you have a v6 you have 3 cats. 4 cyl has 1
Your technician is wrong about your car just quitting. It wont die out on you, you'll just keep damaging it and end up giving a technician like mysel a very healthy paycheck.
the update - yes, there is a service bulletin out for your year accord whether its a 4cyl or 6. The 8th gens have excessive oil consumption and for the sake of time i wont get into why. but Honda is covering this problem, and if your misfire is related to a fouled spark plug due to oil consumption, then Honda will pay for everything. You can expect to be told that they will perform an oil change and begin an oil consumption test. they will have you return in 1000 miles EXACTLY and measure your oil level. If you have burned 1 quart or more in that allotted mileage then your gonna get new piston rings on 4 cyls on a i4, and cyls 1-3 and sometimes 1-4 on a 6 cyl.
sorry to be so long winded, but i had the impression you weren't aware of the "basics" so i thought i would explain.
-chuck
P.S. this is a good example as to why you should go to a dealer. You would already have this information and they most likely would have paid for a tow IF the failure is what is described in the Technical Service Bullitin.
Discussion Starter #5
-chuck
You're right chuck, I don't know the "basics" as I am not a car/Honda mechanic. I work in an entirely different field
So today, I start the car up and get ready to go get the code from the check engine light. Today, the check engine light is not flashing and the car is not running rough! The codes are:
P0300, P0303 and P0306
As I stated in my first post, about 15000 miles ago I had a seriously fouled plug 2 (caked with sludge looking stuff). Replaced the plug and everything has been ok until now. So if I understand you correctly, if I pull out plug 3 or 6 and one is fouled, I should contact honda and mention the service bulletin? They will then perform an oil consumption test and if the accord has burned 1 quart or more, honda will cover the repair?
Discussion Starter #6
Today, the car is not misfiring and the check engine light is off!!!!
I purchased 2 ngk plugs to replace 3 and 6. Will take pictures of the fouled plugs and post here. Chuck, can you confirm my process for Honda is correct?
no, your off track here. chances are you dont have misfires on 3 and 6. they are opposing cylinders, and if one is misfiring its common for the opposing cylinder to code as well. its more likely you have a misfire on cylinder 3 OR cylinder 6.
you shoulndt have purchased anything. if you have an oil fouled cyl 3 plug, and the dealer already replaced them and the software is up to date, than you need piston rings on cylinders 1-3 or 1-4. which is most likely covered under the bullitin. cylinders 5 and 6 are not in any way related to the bullitin and if the misfire is on cylinder 6 than honda is not in any way responsible.
you should take your car to the dealer if you have a cyl-1,2,3, or 4 are fouled again.
Discussion Starter #8
Thats cyl 3. The code gave me 3 codes as i stated in my earlier post.
Heres cyl 6:
Sorry for the blurriness. Thats as good as i could get them. The rest of the plugs do not have that black gunk on them
Take Your Car To The Dealer Now Do Not Touch Anything Yourself On This Engine Which Should Be Covered Under The Class Action Lawsuit Settlement..............period.
your welcome
OMG, now you did it. Put the plug back and go to the dealer.
I'm from Mississippi, and bought my 08 accord used FROM CHEVY dealership (2nd owner) outside of warranty. Mine started running really rough (bogging down, sputtering constantly) this weekend right after CEL started flashing. Went to O'reilys and got a code p3400 also. Also the oil was extremely low and it was just changed less than 1500 miles ago. Went to HONDA dealership and aparrently this is a known issue. They replaced all my sparkplugs and are ordering parts to replace all of my rings as well FOR FREE. God bless Honda!
Discussion Starter #12
Just hung up with honda service and because the CEL is not on or flashing, they will not look at it!! I have to wait to the CEL comes on again?
they will certainly look at it. its a class action. they will know to check the plugs. put the plugs back as many others including mysef have said.
Running NYC
Ouch! Either way the codes should be stored. You dealer doesn't sound too friendly, Don't waste your time calling just bring her in and have your game face on.
bring it in and ask for a manager. tell him you had plugs replaced and they are fouled again. you know about the bullitin and you want you car fixed. if for some CRAZY reason he wont, tell him your leaving the car there, and then get on the phone with Honda corperate. then sit back and watch the tune change.
in my 9 years working at honda ihave NEVER heard of a honda employee telling a customer to ''not come in for service." dealers do not, i repeat DO NOT care who pays. you, or honda. the dealer gets their money.
the only people that care are the technicians who get completely screwed on labor if its warranty. thats it. and there isnt a big line of people who feel sorry for the techs. trust me. LOL
Their computer should pull any code that has come thru. Your car stores them. Mine would go off for a while then come back on. I would definitely go back and ask for a manager. You shouldn't have to spend a dime. Honda knows about this issue.
Discussion Starter #17
So, i just got back from honda dealership. It will have to be re-ringed. If you have a leith honda in your town/city, Do NOT take your car to them. Their service blows!! They lied and we very unworkable....
There is a slight "ticking" in the cyl/engine. How hard is it to "adjust" the valve since they will be in there?
So they were not willing to cover for the repair even after you call Honda Corporate? Were they aware of the class action lawsuit? This is unbelievable! :dunno:
I would call Honda Corporate again, inform them of the situation, and would not back down if the issue is not resolved to your satisfaction!
You purchased their car. They need to stand behind their product. Hire a lawyer if necessary!
they HAVE to adjust the valves with the repair. EVERY time a cylinder head is removed regardless of the nature of the repair that valve have to be adjusted on that cylinder head. if they are only doing the rear bank (cyl 1,2, and 3) than you will only get those valves adjusted. if i were you i would ask them to adjust the other three. THEY DO NOT HAVE TO FOR NOTHING. im gonna go ahead and make that clear now. the tech is not being paid to do the other bank. so more labor is involved and would have to come out of your end. if they are doing rings on cyl's 1,2,3, and 4, then they HAVE to do both banks worth of valve adjustments. no questions asked. its written by honda and i can get you that paperwork if you need it.
Discussion Starter #20
I just hung up with the honda dealership and it says they will be re ringing 1, 2, 3, and 4. He also said he will inspect 5 and 6 and see if they need to be re ringed or not. I asked him to let me know if they do or don't have to be re ringed. Can you PM me that paperwork so i can have it on hand should i meet with resistance? Dude, you have been a great help! Thank you so much
1 - 20 of 37 Posts
