1 - 20 of 68 Posts
I've got a V6 sedan. While it's punchy around town I've always thought it was a little underwhelming when flooring it at highway speeds (overtaking a car on a two lane road scenario). I've noticed when flooring the pedal it seems to run into a hard stop. However, annoyed one day, I decided to push further. Holy crap the car came alive. It dropped down another gear and moved out like it should. Anyone else find this to be the case?
Yeah that's what I was getting at. When I push the pedal down harder than where it feels it should stop it drops down a couple of gears where I think it should. It doesn't do this when I just floor it normally.
Good god. Put it in sport and drop it down to third gear and SHEESH ITS A ROCKET...:naughty:
Houstonian
If you have the V6 auto I believe that VCM will shut off 3 cylinders so that it will save fuel. This might be why your car takes a while to get to full power.. because it needs time to fire up the other 3 cylinders? Correct me if I'm wrong.
Only takes milliseconds for this so unlikely. More likely it's just the throttle by wire algorithm trying to save gas by not kicking down the gears low enough until you put the pedal near the end of its mechanical travel.
HA-420
I know exactly what you mean
If I had the ability to drop it into third this thread wouldn't exist. How do you go about dropping it into third at will? No paddle shifters.
Maybe I drive too much and have too much time to nitpick.
Even doing so, I find the car a little underwhelming. However, this is just like any other car. There's a point where the throttle will cause the kickdown in the transmission. In my old '77 F-100, there was actual mechanical linkage between the throttle and the transmission that controlled this point in the throttle travel.
I agree.
The hesitation when "regular" flooring the car was strange at first, but it is somewhat predictable now after doing this a few times. Someone said it best a while ago in equating the sudden rush of power for this V6 to that of early 90's 4 cylinder turbo'd cars. As for punching the pedal down even further, I would have to try it myself to know, but it's already quite a wild beast as is. :naughty:
Chicago Honda
Op, I have noticed the lack of power but it's highly dependent on what speed I initiate the "flooring" at. For example, if I floor it anywhere between 55 and 70 it automatically drops a gear immediately and takes off like a rocket with tons of power. But if I floor it at anything above 75, then it's random whether or not it will drop the gear and apply power. Mostly at 75 or above it will just stay in that gear and give it all the power it has left which is good but not great at that speed.
This is also HIGHLY dependent on how loaded down the car is.....this thing loses tons of power if you have passengers and luggage...
I'll have to try your trick for pushing even harder but I can't see that being a real thing.....and don't wanna break something. I feel like normally when I floor it I push hard enough anyway because of the nature of what I'm about to do...
Ive got a 4cyl .LX with CVT first time I opened it up on the hYW I thought by mistake they gave me a 6cyl. When I got home I opened the hood to make sure it was a 4 cyl.
I couldn't believe the power of my new 2013 compared to my 2005 honda lx.
CITIUS::INFERIUS::FORTIUS
Powered by VTEC :)
Can't you drop down a gear by just hitting the paddle shifters? Works for me.
Drop in S and then put the pedal to the metal.... have some fun everyone, the V6 is a strong and smooth engine. But sometimes needs to be strung out, its good for it
Car so nice, bought twice
With my car (8G I4), it seems to have a bit of randomness for how far it will downshift when at highway speeds. Sometimes I'll be doing 65 and floor it and it'll go down to 2nd gear and 6k RPM. Sometimes I'll do it and it will only go down to 3rd gear and 4k RPM.
I think it's probably a tranny-logic problem (not really a problem though) and not a pedal problem, but you can run an OBDII adapter + Torque and have it display / log the accelerator pedal position. Maybe it really does need to get pushed 1% harder to go "all the way down".
Did the 2005 LX not have VTEC? I know my '98 LX did.
My mid-90s Acura did not have Vtec but they said that made it prime for a turbo. Apparently I'm NA to the exclusion of all others and not the tuner- type but if I had to do it again, you better believe it woulda been hopped on the roids of the car world- TURBO. (not that there is anything wrong with super-chargers, lol) I calmed myself with the best of both world, VTEC V6 and its been snick snick snick, buttery smooth V6 every since. In essence, I had to buy extended warranty for my gen's achilles heal- AT tranny but that's not anything new that even the 9s or those who got the '9s do not do and too much traffic for MT driving in this urban jungle.
1 - 20 of 68 Posts
