1 - 4 of 4 Posts
i am noticing this fluttering sound when under partial throttle at times now after flashing the stage 2 tune on my 2020 sport 2.0 with 1500 miles.
it seems to be when its trying to build full boost when i dont really need it at times because of the weird throttle response with the pedal and its the re-circulation valve just working over and over to keep the boost level. just wanted to get opinions, as i dont want to mess anything up.
I would reflash to stock and see if it disappeares then reflash stage 2 or even 1 again and see if it goes away, that sounds odd for sure. I'm running stage 2 on ktuner and there is zero fluttering, just like stock. Do you have other mods?
That's your wastegate fluttering to mitigate boost. Did you enable "early spool" or "quick spool" in your tune?
1 - 4 of 4 Posts
