While doing a simple brake pad change this weekend, i took off the drivers front wheel and found that the sway bar link was not connected to the wheel assy, to be honest i have no idea how long it has been like this because i havent had the wheel off in quite some time. I did notice the wheel pulling to the left on certain road imperfections before but i took this as bad tires. Anyway back to my issues, after finally getting the link seating back on the bushing and getting the wheel back on I now heard a loud clunking coming the drivers side. This started on Saturday and got worse yesterday with what felt like really loose steering, if that makes any sense. The sound doesnt change with speed or direction of turn. I havent had a change to get it back on stands but any thoughts? I was thinking it could be the tie rod or the wheel bearing, if it is the tie rod is there any easier way to determine the inner from outer one being the problem other than disconnecting the outer from the hub assy and seeing if it holds in the up position? Any help would be awesome as the car is not undriveable and taking it in is really not an option.
