1 - 8 of 8 Posts
This has become somewhat of an annoyance: it's getting more and more difficult to release the fuel filler flap. I have to press the lever down with force multiple times now..
I'm wondering if this can get any worse and what can be done about it - other than taking it to the shop?
The release cable likely has stretched or gotten bound. Easy fix that should be covered if you're still under warranty.
My flap flops
Bought this 2011 sedan used with 20k on it. Very nice ride.
whenyou pop the fuel flap from inside the cabin, it opens just fine; however it just flops in the breeze rather than open and stay that way with a bit of resistance.
I can get a replacement flap under warranty but the paint shop says it's going to stick out as a color match is more than tough for a small door surrounded by the full quarter panel.
Any recommendations?
seriously? fill up and close it.. or replace it. a good body shop can match color easily.
Unfortunately, the warranty just ended - however I took it to the shop - and they couldn't reproduce it.
Just a couple weeks ago I pretty much had to step on it to get the flap released..
Discussion Starter · #7 ·
It must be the cold - a few days ago when temperatures were around zero it happened again.
Now that I know that the mechanics of the release cable has been checked - is there anything I can do? I don't think my wife would be able to fill her up when it's cold!
I have this same issue as well and it seems to be more apparent in colder weather for sure. What I did was repeatedly open and close the door a few weeks ago (I think the plastic release tab that hold fuel door is just not getting pulled enough) in an effort to kind of wear it in to place. I did it about 50 times or so and haven't had an issue with it since... Just something to try.
1 - 8 of 8 Posts
