1 - 3 of 3 Posts
2004 I4 automatic EX CP 81XXX miles
So I did a very sharp turn yesterday(i did not hit anything, lol) and now my gas pedal and steering wheel shakes/vibrates when cruising from 25 MPH thru 35 MPH after that it doesn't shake/vibrate.
It's more noticeable when going up a hill(from 1900rpm thru 2200rpm even on flat streets). I read the old post but they all concluded that Honda tech will claim this as normal and If you don't believe them they will let you drive another Honda that exhibits the same symptoms.
Anyways for those who had the gas pedal vibration did you guys find a fix or learned to live with it?
I've owned this car since late 2009 when it had 63k miles on it.
The only work the dealer ship did was the engine mounts TSB
Rush fan
Only thing I can think of is loose engine mount/s.
Did my research, and found some old post saying their problem went away when they had their axle changed.
I inspected my axles no sign of rip or tear or leaks
I took it to a professional mechanic and they said their is no visible damage
Anyways they replaced the driver side axle and now my car drives smooth!!!!
I asked them if my axle was bent or what not and they said most likely but you can't see it with your naked eye.
165.08 buck for new axle and labor
Location Los Angeles Ca
1 - 3 of 3 Posts
