The manual says to use Honda fluid; would using GM fluid in a 2009 6/6 be grounds to void the extended warranty?
Just asking as I did use GM at 45k and again at 90k.
The techs aren't CSI so if you had a transmission issue just put Honda fluid in before you take it in.The manual says to use Honda fluid; would using GM fluid in a 2009 6/6 be grounds to void the extended warranty?
