A rolled up $50 bill?what is a good coke air intake
ShhhhhhhhhhhhA rolled up $50 bill?![]()
So something along the lines of maybe this?You will get lots of opinions here. My vote is for Injen.
Can you elaborate on the MAF signal problem you're referring to caused by other intakes?In my experience, the Injen is the only one that actually works properly. They don't screw up the MAF signal. The hydro shield is a nice addition to have.
I'll likely get the Injen when the weather warms up. Did you need to remove the bumper to install the CAI, or where you able to install in through the wheel well?Most aftermarket intakes screw up the MAF signal and trick the car into running rich. That doesn't make more power nor make it faster. The Injen intake actually engineered the section that contains the MAF so that it properly meters and reads the airflow so the computer gets the proper signals. Take a look at an Injen intake, it doesn't just jam the MAF into a random section of oversized tubing.
I pulled the bumper, seemed the easiest route and made it really easy to pull that honkin' big stock system out. I clean the filter once a year, but then I don't drive that much any more. My '15 just ticked over 47k recently. To clean the filter I take a bit of the belly pan in that corner loose, take out the fog light, disconnect the filter and pull it out the bottom. Pulling the fog light out makes it super easy to get at the clamp that holds the filter on. The belly pan section is held in place by those plastic push clips. Pretty easy to do.I'll likely get the Injen when the weather warms up. Did you need to remove the bumper to install the CAI, or where you able to install in through the wheel well?
Also, how often are you needing to clean the air filter -- even with the protective sleeve?
I wasnt aware of this MAF signal problem. I have K&N Cold Typhoon Air Intake 69-1212TS. Possible dumb question so be easy on me i owned it upfront.Most aftermarket intakes screw up the MAF signal and trick the car into running rich. That doesn't make more power nor make it faster. The Injen intake actually engineered the section that contains the MAF so that it properly meters and reads the airflow so the computer gets the proper signals. Take a look at an Injen intake, it doesn't just jam the MAF into a random section of oversized tubing.
