1 - 2 of 2 Posts
Hello,
I had to change the battery, and I got the radio code, but it has a 9 and a 0 in it. The buttons only go 1-6. How do you input a 0 or 9?
Thanks
The correct Honda radio codes only use the numbers 1-6 since there are only 6 buttons. Where did you get the code with a 0 and a 9 in it? Best way is to retrieve it before disconnecting the battery. I presume you tried using the "Radio Codes" sticky since you also posted this question there. If that didnt work you may need to stop by a Honda dealer.
The year and model of your Accord would also be helpful.
1 - 2 of 2 Posts
