1 - 3 of 3 Posts
Just got a new amp and grounded it to a bolt that looks like a common ground at the left side back seat. (8th gen sedan), Is this a good ground source or should I find another ground point? Sorry no pic, no camera. Where/how did you ground your amp. I need to keep the amp mounted in the trunk.
Thanks. :notworthy
sounnds ok, make sure there is NO rust or paint on the metal underneath the bolt
That will work, but I have found that using factory ground locations where other ground wires are going from the factory electrical system can induce engine noise.
1 - 3 of 3 Posts
