1 - 2 of 2 Posts
I am doing a add a fuse fuse tap and included with my radar detector cable is a ground wire.
The wiring harness has a ground but you have to remove the kick panel to get to it. The kick panel has fasteners and part of it goes under the driver's side door molding. This panel is the same one that is where the hood release levee is located.
Here are some pics...
Sent from my SM-N950U using Tapatalk
2021 Honda Accord LX
This is a great reference! I may be years late but thank you, this I just the grounding point I needed. Only issue now is to purchase bigger spade terminal connectors enough to fit around the screw. 🤦‍♂️
1 - 2 of 2 Posts
