same, easy install, works great, no lag between hitting steering wheel control and radio response.It works SUPER easy, there are three wires that you have to hook up, a power, ground, and a signal wire. They are all three at the stereo's wiring harness. Then you plug 3.5mm jack into your new stereo then you're done. Everything in our cars is auto-detected. The instructions that come with it are super easy to follow!
Then it is not designed for steering wheel controls and you are out of luck.What if my deck doesnt have a 3.5mm jack in the back and only RCA plugs?
I used the ASWC with an Alpine W910 and the unit only detected the radio properly and did not auto map the button as you mentioned, although manually programming worked flawless and was very simple to do. Oh this was in a 07 with OEM navi.I am installing ASWC in a 2003 Accord EX coupe. I connected the Axxess ASWC grey/red (pin 5) to the green/red on accord (pin 3). I connected the ASWC black (pin 6) to ground. When I turn the car on the ASWC has power the device runs through the LED flashes. It does not automatically set the button functions-- it should auto-detect according to the Axxess Application Chart. I watched the LED flashes. The ASWC does not detect the Gray/Red wire connection with the Green/red because the Vehicle LED Feedback does not show a long flash on the 4th LED flash (of 7). The ASWC device does however detect my radio (Alpine) because the Radio LED Feedback has a long flash on the 7th LED flash.
Therefore, I know that the red, black and 3.5mm connector are all correct. Do you have any ideas?
