Hi all,
need some help here with this, when I start up the car especially in the morning the ABS light that had gone off at position II would light up momentarily when I crank the engine to start.
I was thinking whether it was due to a weak battery since it hardly happens at any other time of the day.
Also when it does happen, cranking the engine appears to take like a fraction of a sec longer than usual.
Apart this there's no other issue with it.
I'll appreciate all the help you've got. Thanks
