1 - 5 of 5 Posts
the car was running fine and then i went ahead in attempt to jump pin #8 and #13 on the data link connector on the honda accord (1999) and now the car won't start. I think i must have been careless and read the diagram wrong and instead jumped pin #1 and #12. how can i resolve this issue? your expeditious help will be appreciated!
Well, 8 and 13 are blank open holes, 1 is blank and 12 has a red/white wire to it, but is undefined on ISIS as to what it does.
Post a drawing and pic of exactly what pins you jumped and which pin you're calling 1.
01 Accord EX V6
What is it your where trying to do? Did you see any sparks? And last did you check your fuses?
Discussion Starter #4
solved problem
Thanks all for your replies. Basically I wanted to check the base timing and according to my Haynes repair manual, in order to do that, I needed to place the PCM into the base timing mode. This is achieved by jumping pin#s #8 and #13.
Well I did pretty much tried to pull the fuse #13 and to disconnect the battery to see if the PCM would reset (I noticed the check engine light did not come ON when i turn the key (before cranking the motor). But these did not solve the problem. I even pulled the PCM (ECU) out of the car to check it. Well finally i recall there are fuses inside the engine compartment and bang there was the blown fuse. it was on the ignition fuse. After putting in a good fuse, the engine check light came ON when i turned the key and then the car started. Isthere a idiot proof on working around this pin jumping when i want to check the base timing? thx.
Why are you trying to check base timing, the distributor isn't adjustable.
If its out, the cam timing is off.
1 - 5 of 5 Posts
